Altimeter not adding
Hi I want to add altimeter as a complication slot , I am adding circle slot but I can not see altimeter option at customize page of wear app. what should I do?
even I try altitude tag but not working
I am pretty sure there is no [ALTITUDE] tag in WFS . Not all Complications from the Google store give the same results on a Face you have Composed . AMOLED has some nice Comps for free. Make sure when you select a Complication make it the only one in the set . Chose a Comp that has all the possible items you want in it and try them out .
