I learned some new WFS trickery ![]()
A modern watch face with a unique magnifier lens built into the hour hand.
Designed for clarity, realism, and a subtle touch of character.
Features:
• Flat, modern dial with fine detailing
• Moving magnifier effect (no gimmicks, just watchmaking fun)
• Yellow seconds hand for a crisp accent
• Realistic depth with responsive shadows
Instructions for downloading it:
- If you aren’t a member of the testing Google Group join it here using your Google Play email address:
- Download it from here (you will be asked to join the testing):
My OnePlus 3 watch says it needs the “smart mode” to be enabled and claims it is incompatible. Just hit “Apply”. I haven’t really noticed much of a battery drain using the watch face.
