Bitmap image problem
When you add a date with a bitmap for aod, the values apply to the active mode as well. Therefore, it is not possible to separate the aode bitmap from the active mode bitmap. They are both visible at the same time.
to see it only in AoD mode you have to turn off its visibility in normal mode
