% expression in steps and battery
Hi,
Compare to GWD,
there’s no tag to express % after text,
is there any plan to add or
is there any way to add this for now?
It was very useful to choose
where showing only text value or text + % at the same time.
I could add % after tag, but the text size sets to same size.
no other way to differentiate from number value.
BR,
Leojun
Hello. I dont know what text you actually want. In text field put in your tag and write or not the % sign. That is as simple, as it used to be in GWS. To have it different size or font needs aditional text field. Same as it used to need in GWS.
