Follow attached images Are my steps correct in building a complication
I made a simplified model of a watch face and added a complication to customize it on the watch to show the battery percentage for example.. The first image is building the design and sending it to the watch.. The second image is long pressing to customize the watch face and choosing to display the battery percentage on the complication.. In the third final image, the battery symbol does not appear on the watch face
See in your top image . you have selected one complication Format . You have to delete all the others in the group . In the left upper corner of each one is a very fait X click that to delete them . You are doing well . Great to see images of what is going on .
Do you mean the sub-menu of circle complication (text - title - icon-slot bound)? There is no x delete symbol for it, but there is an eye symbol to hide it only.
In the cornes of the Bound Box Selection . Delete the ones you are not useing .
I did all the steps and the problem persists.. Can you, dear, upload a simple design in a WFS format so that I can see the settings?I am very grateful to you for your kind help.
Sometimes when you carefully describe the issue a solution presents itself . When my PC is on I will post something . Standby.
Are you on WFS 1.9.5 . Here is a test we can play with .
COMP_SET_TEST.wfs.ZIP (530.1 KB)
Yes indeed I have WFS 1.9.5… I followed the same steps that you explained in the pictures. On the computer during the preview the battery icon appears (see the attached pictures) but when I upload the design to the watch nothing appears. I think the problem is with the watch, there is something in the watch settings or something.
-The first image shows the design previewed on the computer correctly.
-The second image uses a ready-made design from the ready-made templates on the program, and it contains the battery, but look at the third image, nothing appears on the clock.
Oh my god… I just discovered the reason for the problem, it’s funny… I use an ADB app control to delete some system apps from my phone and watch that I don’t see any use for and that might be consuming battery and memory… I disabled 53 system apps, but luckily I had disabled them and not deleted them, so I enabled them and the watch is back to working with the design I created, which is great. - One more question… The battery is now showing on the watch face, but the font and icon are small. How can I make them bigger?
Have a look at the Settings for each layer in the comp just dont make them bigger than the bounding box . Glad you found a solution to the issue . I must find that preset watch it is nice . I will adjus mt test later . We have guests today .
It would be more logical not to select the complications initially, but to check the necessary ones. But Samsung’s logic is flawed. Sometimes you forget to turn off the unnecessary ones.
Yes . But as you go on you start to remember the undocumented stuff .
