Galaxy Note 10+ with Dex - Max resolution 1920x1080
Hi guys, Is there something to do in order to get 4k display setting available for clicking? Running my DEX on a 2k monitor I’m only being able to see the max resolution of 1920x1080. Is there something I can tweak or anyone is seeing the same issue as I do?
Im using a Galaxy Note 10+ (LATAM)
Thanks!
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for end product questions or concerns. Having said that I’ve moved this to the Samsung DeX category as perhaps a developer will see this and respond.
I would recommend you post using the Samsung Members App or at Samsung support select Contact US and then the Social tab Join the Conversation
Because end user questions disrupt developer discussion this thread will be removed after a short time.
Ron
Samsung Developer Program
