Gear S3 and S2
I would like to reinstall my personal watch faces in my Gear S2 and S3 which no longer work after the updates.
Problem to rebuild TPK
Abstract Art Luna Dalo
Related Menu or Feature:
Detail description of the Feature Request:
Benefit:
What updates are you talking about? Are they to Galaxy Watch Designer or for The watches? For S2 you will have to roll back to GWD 1.6.2 and that is available on THIS PAGE below the download bar is see previous versions.
For Gear S3 that were updated to Tizen 4 you will need to create a new Distributor Certificate in order to upload to that watch.
For GWD 1.6.x you will need to have the 32 bit Java JRE if you removed it. If you have it you will need to add it to the GWD 1.6 ini file.
Ron
Samsung Developer Program
