Gyro Effect issues
What I initially tried to do is make an object rotate only on the X axis and only between 0° and 45°. Unfortunately this is not possible. I can either choose for the object to rotate on both X and Y axis between 0° and 45°, or I can choose for it to rotate only on X axis, but between 0° and 45° AND between -45° and 0°. I found all sorts of solutions, but either they only worked in GWS and NOT on the watch, or they didn’t work at all.
I also added 3 images with explanations, I hope they’re understandable.
Thank you for your time!
