I recently tried to install a custom ROM in my samsung j6+ but halfway through it my PC turned off.
Then the problem starts i decided to reboot my phone but it shows this error “No command” " #Reboot recovery cause is [[check_bootmode]RebootRecoveryWithKey]#
Block-based OTA
Supported API: 3
MANUAL MODE v1.0.0#
E:Failed to mount / cache: Invalid argument
The error message keeps appearing for just a fraction of a second then disappear and appear again
I tried to go to recovery mode but no luck i cant get to it
I drained the battery to turn off the device then go download mode but after get to it, it also keep restarting
help me please. thank you
