I’ve come across all my old watch faces I created for my old Tizen watch, tinkered with them to get them working as expected on WFS and all seems fine until I go to build, build gets to 100% and then throws back an error ‘±’ is not recognized as an internal or external command , operable program or batch file.
Does anyone know how to fix this error or do I just need to start all over?
Thank you
Usually this is a spelling error or invalid path when adding resources. I am advising not to use the import GWS resources but manually add them as this seems to be more common.
The log is located here for most users
Windows : C:\Users{User}\AppData\Roaming\watchfacestudio\dump\main.log
If you are on Mac or installed for all users it may be other places.
Log at the log and you probably can find the issue.
Ron
Samsung Developer Relations
