Moon phase watch face studio
Yes. WFS 1.7.9 has utility that you can only use on WOS5 watches. The weather ones notably. Also the Ranger on the Complications. Since you have been working on 1.7.9 your work will not be backward compatible.
Uncheck the Range Value on your Complications .
Yup I guess for what I intended to do I need to do it all over again…
But in the meantime here are the full graphics of my WFS as I promised
CASIO_20240923_14342255
I am open for suggestions
Looks great . Sadly we do not have access to the Magnetometer data in WFS . If you are using any Weather Tags that pushes it into API34 .
You don’t Face to do anything over again . You just need to take out the API34 stuff .
BTW this is the Extreme tide the other day . CAUSED BY The Harvest Moon . Plus we had a partial Eclipse .
Yeah I found out while researching for this one. But I hope the update will come soon.
WFS is missing some stuff to be close to perfect:
• is alarm on/off tag(or any other thing)
• access to magnetometer
• showing phone battery(although it can be done with the phone battery app, but only in API34 because of complications)
So weather tags are missing in WFS 1.6.10 verion?
Yes . Those things have been asked for but no Action yet . And Yes . You need WFS 1.7.9 to include the weather tags in your Face . Also you need GW 7 or Ultra to run it at the moment . Some say Pixel Watch 3 is ready .
