Possible to detect when AOD screen is activated?
I like to move an element to a certain position once the AOD screen is activated. Is this possible?
Thanks in advance!
Hello,
You can change the visibility option for the normal mode and the AOD mode.
But in this case, the component position is fixed, so if you want to change the position based on AOD mode this is not possible. You can add a tag to change the component position or conditional timeline.
Thanks @Boshra for your feedback - greatly appreciated.
I think you could make a duplicate of the element shift it to desired position and make it visible like Boshra advised and the original invisible in AoD
Thanks Peter for this additional tip - very helpful!
