S21/S21U Add option to change level of JPEG compression (picture quality)
I noticed that the pictures taken with S21U are quite small in size compared to for example to the Xiaomi Mi11 Ultra (both in 12MP mode of course). I know that the size of the photo also depends on how much detail there is in the picture but with the same shots the Mi 11 Ultra usually produces almost twice as large files (e.g. 5 MB vs 3,5 MB on S21U) hinting smaller JPEG compression which can help the image quality.
I would suggest that Samsung could lower the compression or at least add an option for either higher quality image with larger size or lower quality with smaller size. What do you think?
Yes , make it user selectable
Unleash the full potential of the s21 ultra! Or at least give us an option to do so
I totally support this. It’s ridiculous to have a device which is sold on it’s camera qualities to get jpeg files with discernible jpeg compression artefacts.
Please make the jpg quality factor selectable from the camera app.
i also agree on this. please provide us the option for either higher quality image with larger size or lower quality with smaller size.
having tried the GCam mod on the S21U, I can say that the hardware used has so much potential.
