Samsung Weather Complication Showing Incorrect Icon
I have a couple examples of an issue with regards to the Weather Complication.
I had a user report to me that at almost midnight the weather is displaying the Sun rather than the moon.
I tested this on my watch this morning an after the sun had risen i was also getting a Moon rather than the Sun or weather
A couple hours later I checked again and the icon had resolved
I know this is not a function of the Watch Face. More Samsung’s complication. I know there are folks from Samsung that monitor this forum. Is there a way to report this?
More update from my user to show that its not refreshing
He happens to be visiting Turkey from the UK
Shows partly sunny and cloudy at 2303
His other app shows correctly
Thanks in advance
Graham
GDC Watch Faces
Please create a support request with a sample project and short deccriptions.
Just exactly what type of support request am I to make?
This has nothing to do with WFS. WFS correctly displays the fields of the complication.
The issue is the Weather Complication from Samsung does not supply the correct information.
Graham
I’ve found that on WearOS 5, you need to manually refresh the weather in the Samsung Weather Channel app on your watch. I have WearOS 6 on my Ultra and my 6 Classic and this is no longer necessary. It seems to update all by itself.
