I’m trying to set the hand colors.
The software uses Hue/Sat/Lum values that I’m not familiar with and not able to set color I’d like.
I’ve got Photoshop…is there a way to translate RGB values to the values that this software uses.
You need to create your Watch Hands in Photoshop is the only way I know. You can use color picker for Text with a hex value but that is about it.
Ron
Samsung Developer Relations
Thank you. Thank you.
Note that these sliders make changes relative to base image colors - to adjust colors, not to replace them (the image can have multiple colors not just white, to which one would be the RGB value assigned)?
