Stereo output for Odyssey 3D (G90XF)
I cannot find any documentation on how to output stereo to the Odyssey 3D display from an Windows app. I am usually developing apps in Unity3D. Is it for example possible to output a SBS stereo image and view it in 3D on the display?
Any hints are much appreciated.
From what I can find, the only Odyssey 3D only seems to support specific games through the Samsung Reality Hub app and most of the games seems to be unreal engine based.
From the manual:
• Users can only view games that are compatible with Samsung Reality Hub.
• Reality Hub is dedicated software for Odyssey 3D, and allows users to play 3D games and to
convert 3D videos.
• The product’s 3D conversion is only supported through the Reality Hub software installed on a
computer
I would suggest reaching out to Samsung support or business teams regarding the Reality hub software and check if your game could be added to the Reality Hub app or not.
For anyone else wondering about this; it’s using the LeiaSR SDK.
