USB remote control - Enter key not firing events in Tizen web app
USB Remote Control Enter Key Completely Blocked - No Events Fired (Need Help!)
Hi everyone,
I’m facing a critical issue with a custom USB remote control in my Tizen web app and could use a fresh set of eyes.
The Problem:
  • :white_check_mark: Samsung TV Remote Enter (keyCode 13): Works perfectly
  • :white_check_mark: Custom USB Remote (all other keys): Work fine, fire events correctly
  • :cross_mark: Custom USB Remote Enter: Completely blocked - zero events fired (no keydown, keypress, or keyup)
What’s Really Weird: USB Enter DOES activate focused UI elements (e.g., closes alert dialogs, activates buttons) but fires absolutely no capturable keyboard events.
Hardware Details:
  • Custom programmable USB TV remote (HID protocol, sends standard keyboard codes)
  • When tested on PC: All keys including Enter work perfectly and fire normal keyboard events
  • On Tizen TV: Every key works EXCEPT Enter
  • The remote sends keyCode 13 (standard Enter) - verified on PC
What I’ve Tried:
  • Event listeners on document, body, window (all phases - capture and bubble)
  • Hidden input elements to “trick” IME system
  • hwkey-event="enable" in config.xml (already set)
  • <tizen:metadata key="http://samsung.com/tv/metadata/use.ime" value="false"/>
  • <tizen:privilege name="http://tizen.org/privilege/tv.inputdevice"/>
  • Verified with on-screen debug output - other keys show up, Enter shows nothing
Test Code:
javascript
document.addEventListener('keydown', function(e) {
    console.log('Key:', e.keyCode); // Shows all keys except USB Enter
}, true);
My Setup:
  • Tizen web app with iframe loading external SPA
  • All standard USB remote keys work except Enter
  • Samsung documentation says Enter is mandatory and “detected automatically”
Has anyone encountered USB input devices where Enter specifically gets blocked? Is this a known Tizen limitation? Any workarounds?
Thanks in advance!
Hello,
For Smart TV questions, please log in to TV Seller Office: ( Seller2.0 ), go to the 1:1 Q&A section, and ask a question.
You can also find the local content manager.
Your Samsung Content Manager helps you manage various application development and distribution scenarios, such as permission to use partner-level privileges, removing application versions from distribution, and publishing an application in multiple countries or outside of the United States.
To request the contact information for your local Content Manager, you can request this information through the “1:1 Q&A” section.
Thank you,
