Hello,
i have a question regarding the API compatibility of Samsung Soundbars. I have a Samsung HW-Q800A.
Is there a way to control the volume of the Soundbar via a Rest API on the local network?
More important to me would be the ability to control the „intensity“ of the Subwoofer from the soundbar. My plan is to use a Philips Hue Button, which is reprogrammed to call a URL (API) and disable the subwoofer.
It is possible via the SmartThings app, hence i would be suprised, if that was impossible to do it myself.
Help or any advise is highly appreciated!
Best regards,
Markus
