Hi,
is there a fundamental difference in tuning a DVB stream between a Tizen 4.0 (EJ690) and Tizen 6.0 (AU800).
Procedure for Tizen 6:
- create tvwindow globally once
- Set tuneOptions parameter
- call “broadcast.tuneDirect(tuneOptions, this.callbackSuccess, this.callbackError);”.
- how to stop the tuned channel again?
Under Tizen 4:
Using the same procedure as for Tizen 6, the channel is only played when I leave the channel again.
There seems to be a difference in tuning.
Thank you.
