Is it possibke to switch between watch faces on my watch 6 by creating a tap button in watch face design menu?
Instead of the usual method by press down on the customise button and switch over the watches faces.
I guess, its a good idea… it’s like switch colors on the watch.
Thank you.
You can add theme colours and TAP hold your face and change them with Customise . Further customisation can be done with Styles .
Thank you. I will give a try.
