How to convert or create build using react native
I already have tvOS application using to created in React native . that application now working in android and iOS tv . i try to use same code base in samsung tv . first i tried to convert apk to tpk . can’t get any postive result .
My question is
is this possible android rv APK to TPk for samsung tv ?
or
can able to enable samsung in same react native project?
I would suggest you read the FAQs and documentation in the Smart TV Portal
Samsung TVs support only Web applications (“.wgt” files). They do not support native applications (“.tpk” files).
There is a 3rd Party Tutorial for this.
Ron
Samsung Developer Relations
