Hi Samsung Developers,
I have found an edge case problem that my application crashed and maybe TizenOS killed the application.
Normally TizenOS re-launch the application automatically but in this case, I have found that it doesn’t automatically launch app from Launcher URL after crash → then turn on the device.
video: https://www.loom.com/share/e7437f6b8c7642ecb23166c54728abdd
[edit: This link does not work, reformatted to no longer autolink]
My application has two applications including web UI and javascript Service, which I have found that Multitasking | Samsung Developer tizen.application.launch(...);
it is possible to launch application from background service whenever I detected that UI application is killed such like the above video.
The problem is after launching the application from tizen.application.launch
the normal behavior that after turning on the TV it should open my application by default is gone.
Could you please help or any advice?
Device Information:
Model: QM43R
Model Code: LH43QMREBGCXXT
Type No: LH43QMRE
Software version: T-KTM2ELAKUC-2040.1, 2040
SN: 088DHNDMA00001R
Tizen: 4.0, SSSP6
