So my wearable app is using Knox SDK. Since I want to cover everything possible with tests I came upon a problem. I’m basically not able to run tests because Knox SDK API is not defined. I tried to include it in Tizen Setting as I would do in regular app put I only see Platform tab there.
Does anyone knows how to overcome this problem?
Thanks.
Hi Jovan,
You may get appropriate suggestion if you report it to Knox Sdk team regarding your issue.
Check out the link below to get support for knox sdk-
Thanks.
Jovan,
Any luck in getting this figured out? I couldn’t find anything on the Knox sites about this.
Jeremy
@jovan.jocovic - this is how to get your Unit Tests running again:
- open Test Project Properties:C++ Linker:Libraries:
- add to Library Search Path (replace the 4.0 with whatever platform you are targeting):
- “${SDK_INSTALL_PATH}/platforms/tizen-4.0/wearable/rootstraps/wearable-4.0-device.core/usr/lib”
- add to Libraries:
- open Test Project Properties:C Compiler:Includes:
- add to Include paths (replace 4.0 with whatever platform you are targeting)
- “${SDK_INSTALL_PATH}/platforms/tizen-4.0/wearable/rootstraps/wearable-4.0-device.core/usr/include”
- open Test Project Properties:C++ Compiler:Includes:
- Apply and Close - Choose YES to reindex the files
- Build, Run as Tizen Native Unit Test and Coverage
- Rejoice
