Question about Developing apps with Samsung features
Introduction
Hello, this might sound like a non-sence question, but I’ve recently started to wonder how to develop for Samsung devices, for example Samsung Daily, Dex and Bixby Support.
Bixby
I have found the developer guide for the capsules, but reading the documentation I cound’t find out how to make it native to my app
Question
  • Is there documentation for their implementation of those features on and Android app?
Just to be sure you are using the Samsung SDKs in Android Studio and running on a Samsung Device. You can’t use the Samsung items on Non-Samsung Devices.
If you just go to the Build tab here in the Samsung Developer Portal. Some stuff requires you to be a Samsung Partner to access tools, some things allow you to develop but must be a partner to distribute and some is just open SDKs.
I don’t think you can do DeX for all Samsung devices. I believe all of the developer stuff for DeX is on Github.
Ron
Samsung Developer Program
Hi, I have not installed anything so far, I’m researching what i can and can’t implement to the app, for the moment when I start coding.
Thanks, in the build section I now see the Dex, but still couldn’t find how to implement a bixby capsule or a Samsnung Daily card.
Maybe I’m still not looking correctly, but cant seem to find those 2
Bixby is on the Bixby Developers Site It looks like it has a lot of guides there.
[edit: remove broken link]
Ron
