Samsung Android 10 android.intent.action.ACTION_POWER_CONNECTED Not Supported?
Since the Samsung devices upgrade to Android 10, the applications have stopped receiving broadcast messages ACTION_POWER_CONNECTED and ACTION_POWER_DISCONNECTED. There are no errors in the work.
This happens only on Samsung Android 10 devices. On any other devices from other manufacturers, as well as on the Google emulator, Android 10, everything works correctly.
All users of samsung devices after upgrading to android 10 complain about it, but there is nothing I can do. No system settings on the devices in terms of power savings or application resolution in the background help.
What’s going on? Is it possible that Sasung is using other intents now? Maybe some special permissions are required for Samsung devices? Please answer.
Hello ProWax,
Please submit a support request through Developer Support. The Samsung Developer Program Team will help you in this regard.
Thank you.
