Hey, I’m using the following command:
systemManager.setQuickPanelEditMode(CustomDeviceManager.OFF);
How ever, it does not seem to work. I can still freely add and remove icons from the status bar. Is it possible to prevent the user from performing any changes to the status bar?
(Blocking status bar or disabling settings changes are not optional)
Running on Android 11, Samsung Galaxy S20Fe
