according this: Power: Controlling Power Resources
tizen.power.request("SCREEN", "SCREEN_NORMAL");
Where in my code I should use this…? What I need to do is to get my display always on when I´am on app.
On your initial function. On the one that always runs when you open the app.
For instance, if your application is a web app you could add that code on the “onload” event…
OK to maybe there is a problem, that this feature is not available on my app…?
using Tizen.Security;
using Tizen.Sensor;
using Tizen.Location;
using Tizen.System;
namespace Pulsometer
[XamlCompilation(XamlCompilationOptions.Compile)]
public partial class App : Application
public App()
InitializeComponent();
Tizen.Power.Request("SCREEN", "SCREEN_NORMAL");
MainPage = new Pulsometer.MainPage();
There is error: The type or namespace name ‘Power’ does not exist in the namespace ‘Tizen’ (are you missing an assembly reference?)
using Tizen.System.Power or Tizen.Power is not available…?
