Hello.
I’ve building tizen application, and use angular 2+ for it.
I add JSON url to config.xml for smart hub preview support.
<tizen:metadata key='http://samsung.com/tv/metadata/use.preview' value='endpoint_URL=...'></tizen:metadata>
And add this lines to prevent app reload on preview banner click.
<tizen:app-control>
<tizen:src name='index.html' reload='disable'></tizen:src>
<tizen:operation name='http://samsung.com/appcontrol/operation/eden_resume'></tizen:operation>
</tizen:app-control>
But my app reloads on every preview click, and I don’t know how to prevent this.
This is location from app console.
href: "file:///home"
origin: "file://"
pathname: "/home"
As you see, I use routing in my app, and I can’t rewrite all app to use only index.html route.
Maybe there is another solution, how to prevent this app reload?
Thank you for help!
