Once you create bitmap fonts is there a way to rename them or are you stuck with the name you give it on creation?
Thanks
Thanks
I couldn’t find a way to rename it after adding the font.
You can change the font names in WFS . I just don’t think you can change the first one . These shots are from the Example in the Work Box .
BTW try get this sort of enquiry to the WFS Category . There are more People responding there .
Weather_health_D_C.wfs.zip (277.0 KB)
Thank you for responding. I have changed this to the Watch Face Studio Forum. Although this allows to change which bitmap font you use I was looking to actually change the name. From like Cat to Dog or Weather Bitmap to Winter Bitmap.
Thanks
Yeah you change them there . Delet what is there and type what you want . You build or change the font in the Text Layer Font Properties .
