Is there any documentation on communicating with the new Galaxy Ring? I’m under the impression it’s a Wear OS managed device, which should mean Health Services on Wear OS would be the appropriate route. Is this a correct assumption or are there docs out there that I’m just not seeing?
Hi,
As far as I know, Galaxy Ring is not wear OS product, its RTOS.
3rd party applications will not support. You can get the data from Samsung Health using health connect APIs, but you can not filter those data whether it comes from Ring or any other devices.
@cpu.ikemike which solution did you find? I am also interesting in reading out health data from Samsung Ring
