Create Shorter Circular ProgressBar Battery charge as 100%
Hi there…
How can I create a Shorter Circular like (3/4) instead full circle ProgressBar for Battery charge for 100%?
Asset 1@4x
means when the charge hit the last square on the circle picture I sent , it will be 100%.
Thank you.
Hi,
you need to adjust two things down in the properties panel.
  • The starting angle. 0° is at 12h. Full circle is 360°. From your illustration it might be at 8h which equals 240°.
  • The angular distance in your example looks like 8 hour ticks which equals another 240°
Oh My God :scream:. How did I forgot that. So D… of me…
Thanks for the reminder Peter.
Ya you’re… I guess I’m going too fast… lol
Thank you again. the best.
