Enable DDC channel (vis USB C / display port) connection for M8 (M80D)
Enable DDC/CI channel (vis USB C / display port) connection for M8 (M80D) smart monitor. Also, add support Mac OS native for bigthness and Volume control.
Hello,
Would you please clear your query?
Thanks
Shamima
This issue is Monitor (M8D0) doesn’t support DDC /CI commands. This is used to change volume and brigtness of monitor using Keyboard when laptop is connected using USB-C.
Hello,
For Smart TV questions, please log in to TV Seller Office: (Seller2.0), go to the 1:1 Q&A section, and ask a question.
