Heart rate analog hand
HI
I would like to create an analog heart rate measurement with a scale from 30 to 140. How can I do this?
Livello 0
Use the [HR] tag on the rotation setting of the dial hand. For the above image you would start at about 180 and the tag of [HR] * 2 would come pretty close to the range you want
Generally the exercising heart rate goal is 220 minus your age so so you might want it a bit higher max
If you want it digital you can use a progress bar and reveal the numbers below the circle.
Ron
Samsung Developer Relations
