High speed video recording issue on Samsung S23 series
Hello Community,
I am working on an Android Project which requires high-speed video recording a minimum of 120 FPS or higher. On best cases (if supported) control brightness and auto exposure using manual mode.
For reference I am using the Camera2 API as CameraX Video library does not have a ways to control fps of the recording yet.
Investigation and findings:
Here is how I am querying the supported high speed configuration.
internal fun CameraManager.supportedHighSpeedCameraConfigs(): List<SupportedCameraConfig> =
    cameraIdList.flatMap { cameraId ->
        val characteristics = runCatching { getCameraCharacteristics(cameraId) }
            .getOrNull() ?: return@flatMap listOf()
        if (!characteristics.highSpeedSupported) return@flatMap listOf()
        val backCamera = characteristics.lensFacing == CameraMetadata.LENS_FACING_BACK
        val config = characteristics.get(CameraCharacteristics.SCALER_STREAM_CONFIGURATION_MAP)
        config.highSpeedVideoSizes
            .flatMap { size -> config.getHighSpeedVideoFpsRangesFor(size).map { size to it } }
            .map { (size, fps) -> SupportedCameraConfig(-1, cameraId, characteristics, size, fps, backCamera) }
    }.mapIndexed { index, config -> config.copy(id = index) }
        .sortedWith(compareBy({ it.cameraId }, { it.fps.lower != it.fps.upper }, { it.fps.lower }, { it.size.height }))
Returns total of 31 configuration(s) that can be supported high speed recording.
Supported camera configurations:[
	SupportedCameraConfig(id=1, cameraId=0, size=1280x720, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=9, cameraId=0, size=1920x824, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=5, cameraId=0, size=1920x1080, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=3, cameraId=0, size=1280x720, fps=[240, 240], isBackCamera=true),
	SupportedCameraConfig(id=7, cameraId=0, size=1920x1080, fps=[240, 240], isBackCamera=true),
	SupportedCameraConfig(id=0, cameraId=0, size=1280x720, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=2, cameraId=0, size=1280x720, fps=[30, 240], isBackCamera=true),
	SupportedCameraConfig(id=8, cameraId=0, size=1920x824, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=4, cameraId=0, size=1920x1080, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=6, cameraId=0, size=1920x1080, fps=[30, 240], isBackCamera=true),
	SupportedCameraConfig(id=11, cameraId=1, size=1280x720, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=15, cameraId=1, size=1920x824, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=13, cameraId=1, size=1920x1080, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=10, cameraId=1, size=1280x720, fps=[30, 120], isBackCamera=false),
	SupportedCameraConfig(id=14, cameraId=1, size=1920x824, fps=[30, 120], isBackCamera=false),
	SupportedCameraConfig(id=12, cameraId=1, size=1920x1080, fps=[30, 120], isBackCamera=false),
	SupportedCameraConfig(id=17, cameraId=2, size=1280x720, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=25, cameraId=2, size=1920x824, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=21, cameraId=2, size=1920x1080, fps=[120, 120], isBackCamera=true),
	SupportedCameraConfig(id=19, cameraId=2, size=1280x720, fps=[240, 240], isBackCamera=true),
	SupportedCameraConfig(id=23, cameraId=2, size=1920x1080, fps=[240, 240], isBackCamera=true),
	SupportedCameraConfig(id=16, cameraId=2, size=1280x720, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=18, cameraId=2, size=1280x720, fps=[30, 240], isBackCamera=true),
	SupportedCameraConfig(id=24, cameraId=2, size=1920x824, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=20, cameraId=2, size=1920x1080, fps=[30, 120], isBackCamera=true),
	SupportedCameraConfig(id=22, cameraId=2, size=1920x1080, fps=[30, 240], isBackCamera=true),
	SupportedCameraConfig(id=27, cameraId=3, size=1280x720, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=31, cameraId=3, size=1920x824, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=29, cameraId=3, size=1920x1080, fps=[120, 120], isBackCamera=false),
	SupportedCameraConfig(id=26, cameraId=3, size=1280x720, fps=[30, 120], isBackCamera=false),
	SupportedCameraConfig(id=30, cameraId=3, size=1920x824, fps=[30, 120], isBackCamera=false),
	SupportedCameraConfig(id=28, cameraId=3, size=1920x1080, fps=[30, 120], isBackCamera=false)
But none of the configuration can be opened for preview or recording. For your reference here is what I am using to configure capture session.
WHAT ERROR THROWN??
Error get caught by manager.openCamera() > onError(device: CameraDevice, error: Int) { } Mostly error code: 4
    private suspend fun getCameraInfo(backCamera: Boolean, failedConfigIds: List<Int>): CameraInfo? {
        val config = supportedCameraConfigs.filter { it.isBackCamera == backCamera }
            .firstOrNull { it.id !in failedConfigIds }?.also { currentConfigId = it.id }
        if (config == null) cameraNotSupportedEvent.emit(backCamera)
        Logger.info(tag, "Running camera configuration: $config")
        return config?.toCameraInfo()
    // Camera Device
    private var currentDevice: CameraDevice? = null
    private val cameraDevice = cameraInfo.filterNotNull().mapLatest { cameraInfo ->
        getCameraDevice(cameraInfo).also { currentDevice = it }
    @SuppressLint("MissingPermission")
    private suspend fun getCameraDevice(cameraInfo: CameraInfo) = suspendCancellableCoroutine {
        runCatching {
            manager.openCamera(cameraInfo.id, object : CameraDevice.StateCallback() {
                override fun onDisconnected(device: CameraDevice) = Unit
                override fun onOpened(device: CameraDevice) = it.resume(device)
                override fun onError(device: CameraDevice, error: Int) {
                    Logger.error(tag, "[Camera] device: $device encounter error code: $error")
                    showCameraFailedErrorDialog()
            }, cameraHandler)
        }.onFailure { showCameraFailedErrorDialog() }
    private fun showCameraFailedErrorDialog() {
        outputFile = null
        recordingState.value = RecordingState.Idle
        if (currentConfigId !in failedCameraConfigIds.value)
            failedCameraConfigIds.value += currentConfigId
        if (recordingState.value == RecordingState.Recording)
            scope.launch { cameraInfo.value?.let { cameraErrorEvent.emit(it) } }
    // Record Surface
    private lateinit var recordSurface: Surface
    private val preparedRecordSurface = cameraInfo.filterNotNull()
        .map { cameraInfo -> createRecordSurface(cameraInfo) }
    private fun createRecordSurface(cameraInfo: CameraInfo): Surface {
        val surface = MediaCodec.createPersistentInputSurface()
        createRecorder(surface, cameraInfo, getOutputFile()).apply { release() }
        return surface.also { recordSurface = it }
    private fun createRecorder(surface: Surface, cameraInfo: CameraInfo, outputFile: File) =
        MediaRecorder().apply {
            setVideoSource(MediaRecorder.VideoSource.SURFACE)
            setOutputFormat(MediaRecorder.OutputFormat.MPEG_4)
            setOutputFile(outputFile.absolutePath)
            setVideoEncodingBitRate(RECORDER_VIDEO_BITRATE)
            setVideoFrameRate(cameraInfo.fps.upper)
            setVideoSize(cameraInfo.size.width, cameraInfo.size.height)
            setVideoEncoder(MediaRecorder.VideoEncoder.H264)
            setInputSurface(surface)
            setOrientationHint(rotation.value.toScreenRotation())
            prepare()
    // Preview Surface
    private val previewSurface: Surface = preview.holder.surface
    private val preparedPreviewSurface = cameraInfo.filterNotNull()
        .flatMapLatest { preparePreviewSurface(it) }
    private suspend fun preparePreviewSurface(cameraInfo: CameraInfo) = callbackFlow {
        val callback = object : SurfaceHolder.Callback {
            override fun surfaceDestroyed(holder: SurfaceHolder) = Unit
            override fun surfaceChanged(holder: SurfaceHolder, format: Int, w: Int, h: Int) = Unit
            override fun surfaceCreated(holder: SurfaceHolder) {
                preview.setAspectRatio(cameraInfo.size.width, cameraInfo.size.height)
                preview.post { trySendBlocking(preview.holder.surface) }
        preview.holder.addCallback(callback)
        awaitClose { preview.holder.removeCallback(callback) }
    // Recording Session
    private var currentSession: CameraConstrainedHighSpeedCaptureSession? = null
    private val session = combine(
        cameraDevice, preparedPreviewSurface, preparedRecordSurface
    ) { device, preview, record ->
        if (currentDevice == null) return@combine null
        createCaptureSession(device, listOf(preview, record)).also { currentSession = it }
    }.filterNotNull()
    private suspend fun createCaptureSession(device: CameraDevice, surfaces: List<Surface>) =
        suspendCancellableCoroutine { continuation ->
            device.createCaptureSession(
                SessionConfiguration(
                    SessionConfiguration.SESSION_HIGH_SPEED,
                    surfaces.map { OutputConfiguration(it) },
                    HandlerExecutor(cameraHandler?.looper ?: Looper.getMainLooper()),
                    object : CameraCaptureSession.StateCallback() {
                        override fun onConfigured(session: CameraCaptureSession) =
                            continuation.resume(session as CameraConstrainedHighSpeedCaptureSession)
                        override fun onConfigureFailed(session: CameraCaptureSession) {
                            val exc = RuntimeException("Camera ${device.id} Session Config failed")
                            continuation.resumeWithException(exc)
    // Capture Request
    private val captureRequest = combine(
        session, currentZoom, brightness.distinctUntilChanged(), recordingStarted
    ) { session, zoom, brightness, record ->
        val cameraInfo = cameraInfo.value ?: return@combine null
        val characteristics = runCatching { manager.getCameraCharacteristics(cameraInfo.id) }
            .getOrNull() ?: return@combine null
        val zoomScalar = characteristics.getZoomedRect(zoom)
        CaptureRequestConfig(session, cameraInfo, characteristics, zoomScalar, brightness, record)
            .also { runCatching { launchCaptureRequest(it) }.getOrNull() }
    }.filterNotNull().debounce(200)
        .distinctUntilChangedBy { it.record }
    private suspend fun launchCaptureRequest(config: CaptureRequestConfig) = withContext(Dispatchers.IO) {
        if (currentDevice == null) return@withContext
        Logger.debug(tag, "launchCaptureRequest(): $config")
        val template = if (config.record) CameraDevice.TEMPLATE_RECORD else CameraDevice.TEMPLATE_PREVIEW
        val builder = config.session.device.createCaptureRequest(template)
        builder.apply {
            addTarget(previewSurface)
            addTarget(recordSurface).takeIf { config.record }
            val autoExposure = config.brightness < 0
            set(CaptureRequest.CONTROL_AE_MODE, if (autoExposure) CONTROL_AE_MODE_ON else CONTROL_AE_MODE_OFF)
            if (!autoExposure) {
                set(CaptureRequest.SENSOR_EXPOSURE_TIME, SENSOR_EXPOSURE_TIME)
                set(CaptureRequest.SENSOR_SENSITIVITY, config.brightness)
            val fpsRange = config.cameraInfo.fps.let {
                if (config.record) Range(it.upper, it.upper) else it
            set(CaptureRequest.CONTROL_AE_TARGET_FPS_RANGE, fpsRange)
            set(CaptureRequest.SCALER_CROP_REGION, config.zoomedRect)
        val request = config.session.createHighSpeedRequestList(builder.build())
        config.session.setRepeatingBurst(request, null, cameraHandler)
Any help or guideline would be highly appreciated.
Thanks in Advance.
Adding other series and models where similar issues have been observed.
  1. Samsung S20 Main (Back) camera.
  2. Samsung S21 Ultra Selfie (Front) camera.
Hello indra.sapkota,
60 or higher FPS recording is not supported on Samsung devices officially due to the thermal protection and power consumption.
Hence, Galaxy series devices expose FPS range only up to 30 via CameraCharacteristics#CONTROL_AE_AVAILABLE_TARGET_FPS_RANGES. Also currently there is no plan to support it via Camera2 API.
From your description, I gather that this might be causing the error.
Thanks,
Ummey
Samsung Developer Relations
Hello @UmmeyHB thanks for your reply.
Does that mean that Samsung Devices will no longer support high-speed video recording moving forward including the S23 series? This is quite shocking and disappointing if it is true.
What are the plans for the apps that require high-speed recording? How do we achieve high-speed or slow-motion video recording using Samsung devices? Or there would be no support at all and the developer had to remove Samsung from the supported device list?
Looking for double confirmation.
Best Regards,
Indra
@UmmeyHB I’m sorry but this is absolutely ridiculous - y’all claim to build some of the most powerful phones on the planet and then don’t even support 60 FPS Camera capture for third party apps?
An iPhone 5S (2013!) can do 120 FPS, and an iPhone 8 (2017!) can do 240 FPS recordings.
I think the most ridiculous part here is that Camera2 CameraCharacteristics lists 60 FPS as a supported FPS range on many Samsung phones, but the session just disconnects when trying to use 60 FPS - without any errors!
Hi @indra.sapkota thanks for bringing up this issue. I am facing the same thing with Samsung Galaxy s20+. I am building an app which requires to record videos at 120FPS and even though I see that the back camera supports 120FPS at 1920x1080 resolution, the app crashes with no understandable errors. The app works perfectly fine on a Pixel 4a and 6a.
Did you find a resolution for Samsung phones? I would greatly appreciate if you have found a way to record at more than 60FPS (120FPS).
@UmmeyHB is it really true that Samsung Galaxy S series does not allow third-party apps to record a high speed video (e.g., at 120FPS)?
Best Wishes
Hello @revelio2see, Unfortunately, No.
Other than graceful handling of the error there is no way out. Here are the devices I have come through and tested and made to work with high-speed recording at 120 FPS configuration.
The funny thing is the result varies from device to device. High-speed video capture may work on S22 sold in Vietnam but not the US lol
Here is the further mode update on the S24 Series
None of the S24 series devices (S24, S24+, S24 Ultra) can record 120 FPS video recording. :disappointed:
With this move, we will drop Samsung from the official support devices for our application and I might stop tracking the upcoming series of the Samsung device.
Good Luck!
This is ridiculous.
S20+ main camera application can record 1080/4K at 60 FPS, 8K at 24 FPS, and 240/960 high speed and yet all of these modes are blocked from third party applications.
So the excuse of “the phone can’t handle it” does not apply here. You are purposefully blocking applications from using this feature that is fully functional otherwise.
Is this still the case? Disappointing since things like this is why I went with a Samsung in the first place.
