There are no longer any Free Sellers all sellers are not commercial sellerts. If you can cancel your application for commercial seller and start a new one. If you have any questions on applying the second time ask here and I’ll find out how to fill in the form without DUNS number for themes sellers.
I sent him many time i’m themes seller only but they send me need duns I expect that they send the same message to everyone without reading and understanding the problem or my message
I expect that is what they are doing. The DUNS system is being repaired and the Commercial sellers are not being reviewed starting today. Hopefully this is fixed by with that “maintenance”
Did you apply to be a Watch Face Designer? I don’t know if they are still reviewing those or not. If you don’t get a positive response by the end of this month they you probably were not accepted.
Only a very few are accepted and it took quite a while to approve the last time and I don’t think they were notified until October. When they say results in December or January due to the holidays.
Hi,
I’ve been waiting for almost 2 weeks now and I still haven’t got any reply from them. Commercial Distribution Request in Progress
Could you do something for me please? I don’t want to wait for a few months before they reply to me
@benkyearn
Usually the Request in Progress means your Duns was entered but needs to be validated that can take up to 10 working days. Last week was a holiday week for some parts of the world and that may have also extended it.
Please let me know if you are applying to be a commercial seller for Watch Apps or Themes or Android without a DUNS number.
I have applied to be a commercial seller for Android with DUNS number. It’s been more than 2 weeks. I haven’t received any info since then. Can you help me as well with commercial request? I have provided every necessary details and I want to publish some android games as soon as possible. I have a tight deadline. Any help would be appreciated.
What is your status, is it pending or Standby ? For international banking it is not unusual for it to take a couple weeks to verify and that is probably what is the hold up. If you use Pay Pal it is a few days.
If there isn’t standby or pending then you should contact the Seller Portal Sign in click on Help then click on Contact Us. If a pop up shows asking if you meant samsung.com ignore or close it. Fill in the form putting N/A for any non relevant by mandatory box and ask for an update on the Status.
When I applied the were very strict that the bank information be exactly the same as the seller ID’s name and they don’t tell you what the issue is unless you ask.
When I applied years ago my ID had 3 names and the application only had room for two names First and Last I had to change the first name from First to “First Middle”
Thanks for getting back to me so quickly. The status of is “Commercial Distribution Request in Progress”. Pay pal is not available in my country so I’m using banking option and yes every detail matches. Most of details were filled automatically when I put in the DUNS number. Remaining details match exactly letter by letter.
I just double checked it from profile section. Company name matches with account holder. Representative name also match with primary contact. I don’t have a middle name issue.
If it is in progress then it wasn’t rejected and you may have to wait a week longer. As I said international banking can take some time to be verified. Two weeks is not unusual. If you don’t get a status change by Tuesday please open a Seller Portal support request.
