Description:
We encountered an issue where the following exception is thrown on some Samsung devices:
Caused by java.security.ProviderException: Keystore key generation failed
Affected Devices:
- Samsung e3q
- Samsung dm3q
- Samsung dm2q
The issue occurs inconsistently and seems to happen randomly. The same code runs successfully on other Android devices.
Steps to Reproduce:
- Use the following Kotlin code to generate a key:
val specBuilder: KeyGenParameterSpec.Builder = KeyGenParameterSpec.Builder(
keyAlias,
KeyProperties.PURPOSE_ENCRYPT or KeyProperties.PURPOSE_DECRYPT
.setBlockModes(KeyProperties.BLOCK_MODE_GCM)
.setEncryptionPaddings(KeyProperties.ENCRYPTION_PADDING_NONE)
.setRandomizedEncryptionRequired(true)
.setUserAuthenticationRequired(false)
.setKeySize(256)
val keyGenerator = KeyGenerator.getInstance(
KeyProperties.KEY_ALGORITHM_AES, "AndroidKeyStore"
keyGenerator.init(specBuilder.build())
keyGenerator.generateKey()
Expected Behavior: The key should be generated successfully without any exceptions.
Actual Behavior: The key generation fails with the java.security.ProviderException.
