Is ONE (On-device Neural Engine) compatible with the Exynos 1380 NPU?
I’m considering using ONE (On-device Neural Engine) for my Exynos 1380-based device. However, I haven’t been able to find detailed documentation or any community references on its implementation. Any guidance would be greatly appreciated.
Hello,
Did you mean Samsung Neural SDK?
Currently this is not available for the 3rd party developers.
Btw, found this github link also: GitHub - Samsung/ONE: On-device Neural Engine
Thanks!
Thank you for your prompt response.
I understand that the Samsung Neural SDK was phased out and (maybe) replaced by ONE. I had already checked the ONE GitHub repository, but I couldn’t find any information about using the Exynos 1380 NPU with Android. I even came across a discussion that suggests it hasn’t been tested yet.
In the meantime, I’ve found some indications that TensorFlow Lite might be a viable option, so I’m going to explore that further.
I would greatly appreciate any guidance or suggestions you might have.
Thank you again for your time and assistance.
Has TensorFlow Lite worked? I have googled and can’t find any clue indicate npu is available.
