I get an error when I try to import the msf-2.3.4.min.js file which comes in that package. Trying to implement just the basic code to discover TV in my network.
Did you solve the problem? I have the similar issue with msf-2.3.4.min.js
When I run
var search = msf.search();
search.on('found', function(services) {
for (var i = 0; i < services.length; i++) {
console.log('Found service ' + services[i].name);
alert(services[i].name);
search.start();
on emulator - nothing happens.
Run on the device SM-R800 (galaxy watch) cause error
Uncaught (in promise) DOMException: Failed to set local offer sdp: Failed to create channels.
version msf-2.0.22.min.js does nothing for emulator and for device.
I have the same issue. The error is caused by the IP address parsing snippet below:
// Line below is from source map: msf://lib/util/Search.js line 54
pc.onicecandidate = function(ice){ //listen for candidate events
if(!ice || !ice.candidate || !ice.candidate.candidate) return;
var myIP = /([0-9]{1,3}(\.[0-9]{1,3}){3}|[a-f0-9]{1,4}(:[a-f0-9]{1,4}){7})/.exec(ice.candidate.candidate)[1];
var pc2 = new MTgetByURI(myIP);
setTimeout(function(){sendTVList();},3000);
pc.onicecandidate = noop;
There is no IP address in ice.candidate.candidate and therefore no match from RegExp.exec(). The strings I have encountered in ice.candidate.candidate are:
Chrome 108.0.5359.124 (64-bit) on Linux:
"candidate:3568087678 1 udp 2113937151 ef312aaf-9672-41cf-9e82-df01ea85b8e2.local 54875 typ host generation 0 ufrag nJF2 network-cost 999"
Firefox Developer edition 109.0b9 (64-bit) on Linux:
"candidate:0 1 UDP 2122187007 c17ee565-5ac9-421b-aa61-ccd34a205f37.local 59176 typ host"
