How does the Boolean expression work in [BATT_IS_LOW]?
I’ve tried these two and they are not working, at least not working in the emulator.
([BATT_IS_LOW]==1) ? 100: 0
[BATT_IS_LOW]==1
[BATT_IS_LOW]==1
Hi, in documentation it states the tag returns either 0 or 1.
Maybe it is another topic for feature request: add battery states to preview settings.
Currently when you put the tag in a text field it shows 0 even if the battery slider is on 0%.
Same goes for the battery charging, there is no way to test the design in preview.
In device section there is only the battery % slider.
I see, I assume the [BATT_IS_LOW] will be triggered when the battery % slider is below 15%.
I agree and will add it as a suggestion.
@X9_Studio I’m not sure what triggers Battery Low it may be a percent or it may be a time remaining factor.
I couldn’t find the exact description in the Android docs.
Ron
Samsung Developer Relations
It looks like [BATT_IS_LOW] is related to charging state, I missed the description where it states it has two conditions that must be met.
Yes, it would be great to have charging state simulated in preview like GWD does.
