Hi,
During my Tizen .NET Xamarin Forms application development for Tizen TV I faced with problem.
I had tried to launch application on physical device and it gave me next error
“[FAIL] SQLitePCLRaw.provider.sqlite3.dll refers a forbidden assembly directly - sqlite3
” because of SQLitePCLRaw.provider.sqlite3.netstandard11.
Then I removed it and got another error
“[FAIL] Xamarin.Forms.Platform.Tizen.dll refers a forbidden assembly directly - libevas.so 1 :(”.
How can I fix this problem?
According to this post https://github.com/SamsungDForum/JuvoPlayer/issues/6#issuecomment-547338585, I can work for Samsung Partner Company as Partner Developer and get information how to switch off security verification mechanism. Does it really help?
If it works and I can switch off security on my device, can I further publish my app to Samsung Apps TV Seller Office with those third-party libraries?
Will it match its requirements? Or the only way around is to use pure database without third-party libraries. It’s not only about sqlite, others NuGet packages have similar problem.
Best Regards,
Vitalii
