When we execute fstatat syscall manually using a machine code from allocated memory a random crash occurred in the native C++ application. After a long time analyzing of the problem, the reason is still unknown to me.
This happens randomly and only on Samsung devices which is running on android 11 version. (Android 10 and 12 works as expected, at least I can`t reproduce it using my devices)
I noticed that a small timeout after memory allocation can resolve issue.
void* addr = mmap(NULL, instr_size, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANON, -1, 0);
copy_memory(addr, instr, instr_size); // Copy syscall instruction to allocated memory
// Looks like a small usleep(100); timeout here can resolve the issue
We execute the following machine code:
d28009e8 mov x8, #0x4f // #79
d4000001 svc #0x0
00000000
00000000
d65f03c0 ret
And as result a random crash occurred:
Build fingerprint: 'samsung/z3sxeea/z3s:11/RP1A.200720.012/G988BXXSCDUJ5:user/release-keys'
Revision: '23'
ABI: 'arm64'
Timestamp: 2021-12-28 14:06:11+0200
pid: 28557, tid: 31727, name: AsyncTask #3 >>> com.meapay.pos.test.app <<<
uid: 10805
signal 4 (SIGILL), code 1 (ILL_ILLOPC), fault addr 0x710ebfb000 (*pc=0xd28009e8)
x0 00000000ffffff9c x1 0000006e4e750c10 x2 0000006d8fdbfdf8 x3 0000000000000000
x4 000000710ebfb000 x5 0000006d8fdbf6a0 x6 0000006e5e708c50 x7 0000006e5e708c50
x8 000000710ebfb000 x9 0000000000000000 x10 95bad00e5839dd5b x11 0000000000000001
x12 0000000000000000 x13 719f9b5af5885aa6 x14 93a3ca420a3b335f x15 6c5c3fffffffffff
x16 0000006d990a2410 x17 000000710f39b580 x18 0000006d8b97a000 x19 0000006f8e7a7c90
x20 0000000000000000 x21 0000006f8e7a7c90 x22 0000006d8fdc5000 x23 0000006f8e7a7d48
x24 0000006e14ffaa00 x25 0000006d8fdc5000 x26 00000000000000d1 x27 0000000000000000
x28 0000000000000000 x29 0000006d8fdbf860
lr 0000006d98214b84 sp 0000006d8fdbf800 pc 000000710ebfb000 pst 0000000060000000
backtrace:
#00 pc 0000000000001000 <anonymous:710ebfa000>
memory near x4:
000000710ebfafe0 0000000000000000 0000000000000000 ................
000000710ebfaff0 0000000000000000 0000000000000000 ................
000000710ebfb000 d4000001d28009e8 00000000d65f03c0 .........._.....
Tombstone file:
tombstone_30.zip (60.8 KB)
Could anyone tell me what can be for reason of this? Or maybe official issue already registered for similar issue?
