S90D OLED 4K Smart TV - Plex
I am trying to determine if a S90D OLED 4K Smart TV is compatible with Plex. I haven’t purchased the unit yet but plan to. Has anyone else had Plex work on a later model smart TV?
I have no idea how or if need to use ’ TV Extension Image 8.0.1’ - https://developer.samsung.com/smarttv/develop/tools/tv-extension/download.html
Hello,
All Tizen based Samsung Smart TV supports Plex
Good luck trying to install it - Samsung seems to only want you to use their apps. On other devices installing apps is hard to miss. I’m pretty technical and so far I haven’t figured it out and I’ve spent over 10 minutes trying to do it. On normal TVs and devices you go to apps - install app if it isn’t listed and you are done. Can’t find install app.
