On th Samsung Health Sdk page in the Sample section there is a project SampleService.
When I download the project files it gives me project files for FoodNote app.
Where can I download SampleService app project files?
Thanks for reporting this. I have asked the portal team to fix the download link. It may take a day or two so thank you for your patience.
Ron
Samsung Developer Program
Thank you. It will be very helpful.
Hello,
The project files are available now - but I am getting
java.nio.file.AccessDeniedException
while building the project - any suggestions?
I read in StackOverflow that you get this exception if the files are read only or there is a file directory problem. Check those if that isn’t the problem can you open a support request from your SDP Dashboard.
Ron
