Sdk incompatible, any solution? complication problems
I just started to have this message when I tried to use the complications. very funny… never happened before.
How can I resolve this.? please…
Thank you.
Do not use complications with Range Value or weather tags. These have needed Wearos 5 since the WFS version 1.7.9.
You’ll get an update soon. Only after updating your watch you will be able to use WFS 1.7.9.
Aw , I see…
it looks like the circle complication is not working… the rest of the complications are working so far.
Thnx anyways…
Switch off Ranged Value in the Comps and don’t use any Weather stuff .
Sorry Russellcresser. I didn’t know what you meant by that.
I didn’t get the shortcuts.
Thank you anyways.
Sorry . I realise what I said was misstyped and mentioned earlier in the Topic .
