I have Note10 and sometimes i connect it by cable to my car (Opel) to use maps, before last update , i can select either sim 1 or sim 2 to make the call directly while the mobile is connected to the car, after installing the latest update the two icons of sim1 or sim2 are disappeared where you have to click call and then a new message appear to ask you make the call either by sim1 or sim2, unfortunately this message doesn’t appear if the mobile is connected to the car by cable and i have to disconnect the mobile to make the call and then connect back to the car
