Hi guys,
I have searched the forum and cant seem to find a definative answer. Is it possible for the stock sunrise sunset complication to show both not the next one, or is it only thr next event it shows?
If so does anyone knownof a 3rd paty complication that will allow me to show both?
Thanks!
It is only the next event that shows. The complication Suite by @amoledwatchfaces has a Sunrise & Sunset complication but it doesn’t seem to be working correctly for the size of my complication. Maybe they can respond here.
Ron
Samsung Developer Relations
Thank you Ron, I’ll have a play with that in various complocation layouts and see. Hopefully @amoledwatchfaces will get back to us
Hi Ron, what’s not working exactly? I’ll try to help.
Complications Suite provides only upcoming event so Sunrise time after sunset and sunset time after sunrise. I have a request for both but I was not able to find some proper combination.
Best would be two icons + both sunset / sunrise but this wont help you in WFS.
@jsmith88 . I have SR SS seperate as two Comps . The developer is very busy with his Day job at the moment . If you prep some slots I am certain he will put you in as a Tester . I will check when they go on release .
The top one is complication suite Sunrise & Sunset the bottom one is Sunrise Sunset countdown
I think they are both long text complications It is a test watch that has been changed.
location permission was granted when in use
Ron
It looks like you didn’t set up location access in the app (coarse location). Location is needed for SS / SR.
Awesome yeah please do I’ll be designing over the next few days so i can test when ready!
Jeff is keen to include you in the Testing Team . Contact him on the Admin email . tiborg.iot@gmail.com .
That was it, I added it to permissions not in the App itself.
But I don’t see both Sunset and Sunrise
Ron
@amoledwatchfaces is it possible to show both at the same time?
Thanks @russellcresser I’ll reach out to Jeff when I get a chance
With one complication, possible but logical only in the LONG_TEXT type with one Icon.
So only with one Icon using long text, but is there a way to separate the 2 values (SR and SS) to move them to different places or different colours for example?
