I contacted to the developer and they advised me to use extra apps,plugins and finally solved my problem.I can use countdown progress bar to sunrise/sunset,calories,floors,moon phase with percentage,etc.
Wow . I did not know we could do that thank you . Topic Bookmarked .
I am using health plugin,Google weather and complication suite by Amoled watchfaces.I am sure that software is as important as hardware.Without a good software it looks like a fast sports car with a rookie driver.
Yes indeed . Samsung / Google don’t want us to make stuff that is power hungry but let White faces out there .
I have not seen the Health Plugin . I also use OMLED utilitys . Great apps but can not pull data from them . You are working on WFS 1.8.10 .
Could you share the link the developers gave you for the Extra Apps and Plugins I can not find them . What I want is the Time as data for the Sr Ss . I presume you are using the Amoled App and using it with the progress bar Comp .
I am using mostly Amoled watchfaces and developer recommended these:
You’re welcome.You and developer really helped me.
Right but Apple watches have a lot of gorgeous and functional watch faces but Wearos and Samsung must be better in this field.
Thanks very much indeed . Will have a look at those .
@ilhamibaykal . I can not see a progress bar for sunrise to sunset in those apps above . Please show me how you got it to work . Thank you .
Quick question that relates to the Sunrise/Sunset complication in WFS: Is there a way to get a monochrome icon rather that the colored default version?
After installing a suitable watch face,you must customise it,there is an option as sunrise/sunset countdown (first complication suite must be installed),you must choose it.
Yes I was looking at that it does not animate the progress bar .
