Dear Users,
I am trying to revolve a text around an ellipse using the seconds count. The problem is that it is not so smooth. whats the function for it
Dear Users,
I moved this to Watch Face Studio, if you are using Galaxy Watch Studio let me know and I’ll move it there.
Ron
Samsung Developer Relations
If it is static text, make an image of it and insert it as second hand. there you can use the sweep movement setting.
If you want it to orbit in upright position, it is not possible until they fix the [SEC_MSEC] tag that gives broken data.
Thanks bro. Yes I want the text that displays seconds to revolve around an ellipse. I was able to do it but it is not so smooth. It stops after every second. Something that has to be fixed. Tried all possible combinations.
