Hello,
the current theme tool and also actually Android Q Builds has some Issue with Themes. There are many Text and Colors, which are not right themed.
1. Settings > Themes > Icon is not Themed, See Screenshot 1. Theme Icon Settings.jpg
Issue contains in Settings.apk, which are not included the Color String to get it themed, must be fixed by Firmware Update
2. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > See Screenshot 2 Dolby Atmos.jpg
Suggestion: It can be fixed in Theme Tool. String “rounded” must be delete,as in Theme Tool 9.18
3. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > Adapt Sound > Personalise sound > Dropdown BG not themed, see attached Screenshot 3. Adapt Sound Dropdown.jpg
Suggestion: It must be fixed in Adapt Sound.apk
4. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > Adapt Sound > Personalise sound > Text not themed, see attached Screenshot 4. Adapt Sound Text.jpg
Suggestion: Issue can be fixed by adding color string “L_R” in Theme Tool
5. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > Adapt Sound > Personalise sound > BG has white Line, see attached Screenshot 5. Adapt Sound White Line.jpg
Suggestion: Issue can be fixed by adding color string “stroke_color_rounded” or via App Update to link “stroke_color_rounded” with “window_background_color”
6. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > Adapt Sound > Settings Icon is not themed, see attached Screenshot 6. Adapt Sound Settings Icon.jpg
Suggestion: Issue can be fixed by adding color string “settings_icon_tint” or via Update to link “settings_icon_tint” with “header_text_color”
7. Contacts > Open Contact Profile > Round Stroke Color not themed, see attached Screenshot 7. Contacts Profile.jpg
Suggestion: Issue can be fixed by App Update to link color with Action bar background or via Theme Tool by adding color string “contact_detail_card_background_stroke_color”
8. Phone > Places > Text color not themed, see attached Screenshot 8. Phone Places Start.jpg
Suggestion: Issue can be fixed by App Update to link text color with Primary Text Color and Sub Text Color or via Theme Tool by adding color string “places_ftu_description_text_color” and “places_ftu_main_text_color”
9. Contacts > Settings > Round Stroke Color not themed, see attached Screenshot 9. Contact Settings.jpg
10. Contacts > Create New Contact > Round Stroke Color not themed, see attached Screenshot 10. Contacts Add Contact Stroke.jpg
11. Contacts > Create New Contact > Expand / More Text not themed, see attached Screenshot 11. Contacts New More.jpg
Suggestion: Issue can be fixed by App Update to link color with any Text Color or via Theme Tool by adding color string “editor_viewmore_text”
12. Clock > Settings > Sub Title text not themed, see attached Screenshot 12. Clock Settings.jpg
Suggestion: Issue can be fixed via Theme Tool by adding color string “global_settings_group_label_textcolor”
13. Clock > Settings > Round Stroke Color not themed, see attached Screenshot 13. Clock Settings Stroke.jpg
Suggestion: Issue can be fixed via App Update to Link “clock_list_floating_stroke_color” with “window_background_color” or via Theme Tool by adding color string “clock_list_floating_stroke_color”
14. My Files > See what’s taking up space on your phone Text Color not themed, see attached Screenshot 14. My Files Space Text.jpg
Suggestion: Issue can be fixed via App Update to Link “home_storage_analysis_info_text_color” with “storage_analysis_group_header_title_text” or via Theme Tool by adding color string “home_storage_analysis_info_text_color”
15. My Files > Internal Storage > Any Folder > Navigation Arrow not themed, see attached Screenshot 15. My Files Navigation Arrow.jpg
Suggestion: Issue can be fixed via App Update to link “navigation_view_subtitle_arrow_color” with “path_indicator_sa_btn_color” or via Theme Tool by adding color string back “navigation_view_subtitle_arrow_color”
16. Settings > Sound and vibration > Advanced sound setting > Sound quality and effects > Adapt Sound Stroke Color not themed, see attached Screenshot 16. Sound Effects Stroke.jpg
Suggestion: Issue can be fixed via Firmware Update to link color string “stroke_color_rounded” with “rounded_bg_color” or via Theme Tool by adding color string “stroke_color_rounded”
17. Settings > Digital Wellbeing and parental controls > Work Time, Me Time, Add Icons not themed, see attached Screenshot 17. Digital Wellbeing Icons.jpg
Suggestion: Issue can be fixed via App Update to add color string in ic_dw_ic_work_time, ic_dw_ic_time.xml and ic_dw_ic_add.xml
18. Settings > Digital Wellbeing and parental controls > App Timers > Description Text not themed, see attached Screenshot 18. Digital Wellbeing App Timer.jpg
Suggestion: Issue can be fixed via App Update to link color “dw_description_center_text_color_no_theme” with “dw_content_message_text_color” or via Theme Tool by adding “dw_description_center_text_color_no_theme”
I don’t no why the color is not themed, but if a Theme has a dark grey bg color the text get’s invisible!
19. Settings > Digital Wellbeing and parental controls > Wind down > Description Text not themed, see attached Screenshot 19. Digital Wellbeing Wind Down.jpg
20. Settings > Digital Wellbeing and parental controls > App Timers > Any App > Prev / Next Arrow not themed, see attached Screenshot 20. Digital Wellbeing App Timer App.jpg
Suggestion: Issue must be fixed in App and add Color Option to sesl_date_picker_next.xml and sesl_date_picker_prev.xml
20. Digital Wellbeing App Timer App|236x500
21. Calendar > More > Expand Icon not themed, see attached Screenshot 21. Calendar Expand Icon.jpg
Suggestion: Issue must be fixed in Calendar App, Icon Tint color is not set
22. Device Care > Optimise Now Button is not themed, see attached Screenshot 22. Device Care Btn.jpg
Suggestion: Fix the Issue via next Device Care Update, to get a better visibility with blue themes for the User Experience
23. Device Care > Battery > Battery Usage > Graph Line is not themed, see attached Screenshot 23. Device Graph.jpg
24. Device Care > Optimise Now > Text Color, Checked Icon, Graph Line and Done Button is not themed, see attached Screenshot 24. Device Care Progress.jpg + 24. Device Care Progress_1.jpg
25. Bixby Routines > Tab unselected Text Color is not themed, see attached Screenshot 25. Bixby Routine Unselected Tab.jpg
Suggestion: Fix the Issue via Theme Tool by adding color string “routine_bottom_bar_tab_color”
26. Bixby Routines > Add New Routine > Next Text Color is not themed, see attached Screenshot 26. Bixby Routine Next Text.jpg
Suggestion: Can be fixed via Theme Tool by adding color string “routine_dialog_dim_text_color_blue” with opacity"50"
27. Bixby Routines > Add New Routine > Subtitle Text is not themed, see attached Screenshot 27. Bixby Routine Sub Title.jpg
Suggestion: Can be fixed via Bixby App Update to link color “routine_detail_condition_subtitle_text_color” with “location_picker_list_subheader_text_color” or via Theme Tool by adding color string “routine_detail_condition_subtitle_text_color”
28. Bixby Routines > Add New Routine > BG Stroke Color is not themed, see attached Screenshot 28. Bixby Routine Stroke.jpg
Suggestion: Can be fixed via Bixby App Update to link color “round_stroke_color” with “routine_setting_bg_color” or via Theme Tool by adding color string “round_stroke_color”
29. Bixby Routines > Open any Routine > Sub Text Color is not themed, see attached Screenshot 29. Bixby Routine Sub Text.jpg
Suggestion: Can be fixed via Bixby App Update to link color “routine_tile_routine_param_text_color” with “routine_dashboard_secondary_text_color” or via Theme Tool by adding color string “routine_tile_routine_param_text_color”
30. Bixby Routines > Open any Routine > BG Stroke Color is not themed, see attached Screenshot 30. Bixby Routine App Stroke.jpg
31. Homescreen > Volume Panel > Use Volume key for media Description Text Color is not themed, see attached Screenshot 31. Volume.jpg
Suggestion: Must be fixed via Theme Tool by adding color “volume_panel_media_control_description_color” under Common
32. Homescreen > Volume Panel > Volume Panel Stroke Color is not themed, see attached Screenshot 32. Volume Panel Stroke.jpg
Suggestion: Must be fixed via Theme Tool by adding color "volume_panel_stroke_color“
33. Homescreen > Quick Panel > Menu > Dropdown Stroke Color is not themed, see attached Screenshot 33. Quick Panel Drop Stroke.jpg
Suggestion: Must be fixed via Theme Tool by adding the color string for Dropdown Stroke Color
34. Apply Theme > Dark Mode On > Quick Panel > Track Background Color is same as Progress Track BG Color, see attached Screenshot 33. Quick Dark Mode Panel.jpg
Suggestion: Must be fixed in Theme Tool add Dark Mode, choose a darker Blue Color for Track BG Color
These Issues should be fixed for a better user experience, since certain theme colors (for example a blue theme or gray theme) can lead to complications and some colors are no longer recognizable.
So please Samsung Developers spend more time to test the Theme Tool enough of unthemed Colors before Release or give us the Option to particpate in a Beta Ring, like Windows 10 Insiders.
There are many thinks which must to improved about Galaxy Themes, in recent years the quality has decreased with the theme tool. too many errors with every new update that could be avoided.
Of course it looks not professional in the moment with so many bugs. In the other Thread Actually Bugs in Galaxy Themes are the Issues are list why Themes are rejected.
Cheers
Alexander
Very useful if dev have time and intentions to read it.
