Did Samsung changed the code for calling those application when I use tap action?
I know they have a preset now so you can choose off…
but some is not there like Weather either Health!
like… similar to this link.
com.samsung.android.shealth OR Weather!
Anyone has new Samsung list?
Thank you
I’m also confused by that… weather and health should be basic “call to apps”.
I guess they are not there because people use different weather and health apps, depending on the phone/watch.
There is the “Custom” option but I don’t know how to find “App ID” of the desired app.
Stuff in here might help. Specifying a package could be risky because not all apps run on all watches; you may need to limit applicability in Play Store.
Thank you Gondwana!
Did I get it right: we need to go to Google store and the app ID is in the link?
That looks plausible. I haven’t tried it because I don’t own a Samsung.
There’s also this, but it probably doesn’t tell you any more.
Thank you @Gondwana so much… Nice and a good sources to know.
Well @Masterboyhr… thank you for the feedback.
I have it installed from Google already.
But I’m using the custom section cos I couldn’t find it in the list…
and custom will allow you to use the links…
but they seems like are not working for anything you pick…
even if I pick a SETTING link. it won’t work.
but they did work before.
I know they have a preset (setting) tap instead of using custom option. But they don’t have so many options in there…
I got the links I believe from @Peter…
Unless Samsung changed them… IDK…
I even done another test on Alarm and this is the link: com.samsung.android.watch.alarm
it says item not found… retry…
I’m just giving an example… I can use the preset tap for Alarm… and it’s working fine.
but we don’t have lots choices, this is the problem.
Thanks anyways…
